Hello, The images sent in the first message were stacked only - I did not save the individual frames.
I made a set tonight in poor conditions - clouds coming in. But I think you can see distorted faint stars in the upper left of the single frame . I have included a stacked image as well. A denoised version removed the faint stars.
This set was made using the default LPR filter - perhaps that is related?
If you want I can make another set with individual frame when the weather clears.
thanks
btw I had to copy the single frame and reduce its size so that this site would accept it.
