I just received an EFW (7x2in) for my rig and now went to flip my CAA into 180deg as the EFW would collide with the mount if it were to rotate 360deg. My issue is that when I switched it to 180 mode, it seems to have remapped the range to some arbitrary number and not 0 & 180deg. I forget the exact numbers it's locked to but now I have to keep the CAA at a very odd angle in order to get the proper mechanical limits for my rig.
There should be an option for absolute limits or calibrated limits from the last plate solve. Some of our rigs won't allow 360deg for whatever reason. If we know that specific rotational angles would collide, we should at least be able to set a range (manually) that the CAA will avoid no matter any other logic.
