My S50 won’t focus on deep sky objects. How do you manually focus on something you can’t see
311nB580 Read tutorial, focus manually, save focus position to default value.
You can manually adjust the focus:https://h5.seestar.com/course/79210 Alternatively, you can modify the default focus position, since the autofocus works by moving up and down relative to that default position.
how do i know what to set the default to?
311nB580 use plejades or similar bright objects, run auto focus, then look at the setting end set this at view visible object when auto focus didn't succeed and is lost in space
thanks
leontodon thank you. That’s where I was going. Much better
