Hi, I have a suggestion for improving the app.
Often, you use your smartphone, but sometimes you also use a tablet.
Currently, you only have the exact same plan on the device you create it on. Unfortunately, it's not available on the second device.
Wouldn't it be possible to transfer the plans from one device to another?
That would be a great improvement, as you would then have the same plans on all your devices.
It often happens that you set off with different devices.
Regards
