Dsqh3WbQ
Regarding the Wi-Fi disconnection issue you’ve experienced, our technical analysis suggests this is often related to interference in the 2.4GHz band, which is commonly congested with IoT devices at home.
We recommend trying the following steps, which can greatly improve connection stability:
Switch to a 5GHz Wi-Fi network if your router and ASIAir Plus support it. The 5GHz band is generally cleaner and less prone to interference.
When using Station mode, make sure your router does not assign an IP address in the 10.0.0.x range to the ASIAir. It should work normally once assigned an IP in a different subnet (e.g., 192.168.x.x).
Please give these a try—they should help significantly. If the issue persists, feel free to share more details about your setup.
Thank you for your patience and feedback.
