We’re excited to announce that v2.5 is now officially available on the App Store and Google Play! Thanks to all users who helped in the beta period. Especially the Admins and Testers.
New Features
1、Enhanced Mount Control (ASIMount only)
- Added mount parking feature
- Autorun and Plan tasks now support setting "Park" as an end event for the mount
2、Support for Setting and Using Filter Offsets
After switching filters during Autorun or Plan mode, ASIAIR will auto-adjust the EAF focus position based on preset filter offsets
3、New One-Click Save Function in Capture Page - Quickly save the current capture target as a custom celestial object
4、Support temporarily skipping firmware upgrade
5、Create and Manage Frequently Used Equipment Positions from the Home Page
6、Image Information Management
- Supports including the camera angle in the FITS filename and header
- Expanded details in image info pages: includes shot time, file information, object information, camera settings, and file path
7、Supports setting power light status and adjusting fan speed for cameras including ASI2600MM/MC DUO, ASI2600MM/MC Pro and ASI6200MM/MC Pro released in 2025, ASI4400MC Pro, ASI2600MM/MC Air, and ASI585MM/MC Air
8、New Features in the Celestial Object Library
- Ability to edit custom celestial object names, types, and coordinates
- View detailed information about celestial objects
9、Enhancements in Plan Mode
- Added "astronomical twilight" option for start times
- One-click function to clear the current task sequence
Optimized & Fixed
- Adjust the default setting for guiding stability timeout to 60 seconds
- Optimize the star detection algorithm
- Fix the issue where DSLR cameras fail to expose properly in autofocus mode
- Fix the inconsistency between the captured image and the SkyAltas's FOV
- Fix the Takahashi Temma 2 GoTo anomaly issue
- Fix black preview of calibration frames (dark/flat/bias) in Live mode
Notes:
- This version distributed via Google Player only supports Android devices with ARM/ARM64 architecture and does not support x86/x86_64 devices. If your Android device uses an Intel or AMD processor—commonly found in certain tablets, 2-in-1s, or mini PCs—please download the compatible installer from the ZWO official website.
- The attachment shows how to use the new feature.PDFs can be downloaded in two ways.
https://drive.google.com/file/d/186RFF5KoeWy25rcfUX0h2Frw6Fk1Ktnq/view?usp=sharing
