Support@Seestar This is outrageous.
1) The scope behavior CHANGED. Precisely after 3.0.0 app/firmware update.
2) You've started clipping data from the image, 50 to 60% of pixels are completely black instead of faint nebulosity. This is completely destroying the whole purpose of collecting data and stacking it later.
3) You have all the needed examples, your developers need to go through their SVN and review changes in settings or code which introduced severe pixel clipping and revert it.
Will this proceed just like with mosaic framing tilt and GOTO setting issue where you told me "not a bug and desinged in such way" and somehow you fixed that after 4 months like a bug in 3.0.1?
Let me remind you,
wVU1j6V6Aug 28, 2025
This is not an isolated issue. Yesterday I've tried the approach I was suggested at Reddit forums: to enable "Execute enhancement after GOTO" option and try again. This time mosaic was consistent with chosen framing, see how it perfecty worked around the whole frame.
Support@Seestar
Aug 28, 2025
wVU1j6V6
This is not a bug, it's just that we didn't design it this way. We have put forward the requirement, but it is still under evaluation. I hope you can understand.
Jan 5
What's new
- Fixed a framing angle deviation issue when "Execute enhancement after GOTO" is turned off
Can we get a person here which understands the issue and fixes that, like, is it possible to escalate to some tech or second line of support?
