I did new testing yesterday. I polar aligned repeatedly going out of PA and measuring three points again with overall 0.1 0.0 PA in seestar app. I used i think point 2 on South, knowing i will be shooting targets in south.
I have tried 30s exposures - all of them were blurred in RA, S50 was hunting RA+-, then i tried 20s at one target (M31), reject rate around 30% (acceptable comparing to overhead when shooting 10s - S50 won't manage to shoot and save them in time, so often it stucks at 0s time, shorting the real time vs capture time).
on another target - triangulum the reject rate at 30s was 100%
so no change at all.
Result:
10s result - enlongated stars on every other frame, perfect only one in 5 (HRF range 1.5 - 2.5) - looks very periodic, consistent with observed RA movements.
20s exposure results are highly target dependent.
30s is unusable completely.
60s is probably there only to frustrate me even more.
These blinks were taken via stargazing live mode, no mosaic.
note: in the videos there are only subs that were kept by seestar app - i was checking the enlongation / drifting and HRF in NINA.
