Subject: 2.5.2 – CAA and guide camera disconnect/reconnect issues (Duo)
Hi all,
Since updating to 2.5.2 I’ve started having persistent disconnect/reconnect issues during imaging sessions that were not present in 2.5.1. Update happened last night 16/04/2026.
Setup:
ASIAIR Plus
ZWO ASI2600MC Duo (main + internal guide camera)
ZWO CAA (camera rotator)
ZWO EAF
Celestron CGX mount
Power setup:
All devices powered externally via Pegasus power supply.
Nothing powered from ASIAIR outputs (tested to rule out voltage issues).
Connection layout:
All devices connected directly to ASIAIR USB ports except CAA through camera. May try to connect CAA to ASIAIR and connect EAF to camera USB (2nd USB 3.0 used for external storage)
Issue:
Main camera remains connected and stable
Guide camera (within the Duo) repeatedly disconnects and reconnects
CAA also disconnects and reconnects intermittently
Happens throughout the night, making guiding unreliable
Important observations:
System was stable on 2.5.1 with identical hardware and setup.
Changing power configuration made no difference.
Does not appear to be a full USB reset, as the main camera remains connected.
Issue seems to affect “secondary” devices (guide cam + CAA).
Seems to be a USB hub issue within the Duo.
ASIAIR app showing voltage warning.
Impact:
Guiding drops out due to guide camera reconnecting.
Imaging sessions require constant intervention.
System currently not usable for unattended imaging.
Question:
Is anyone else seeing similar behaviour with 2.5.2, particularly with:
ASI2600MC Duo (guide cam disconnects)
CAA instability
