Moontanner
Yup, the logs look like this when the plan session fails due to an "exposure failure":
2026/04/15 02:12:28 Exposure 120.0s image 91#
2026/04/15 02:14:31 Exposure 120.0s image 92#
2026/04/15 02:16:34 Exposure 120.0s image 93#
2026/04/15 02:18:37 [Guide] Dither
2026/04/15 02:18:37 [Guide] Dither Settle
2026/04/15 02:19:07 [Guide] Settle Done
2026/04/15 02:19:07 Exposure 120.0s image 94#
2026/04/15 02:23:23 Exposure 120.0s image 94# failed
2026/04/15 02:23:23 [Guide] Stop Guiding
2026/04/15 02:23:23 [Autorun|End] Pause Autorun
2026/04/15 02:23:23 Pause Plan New Plan
2026/04/15 02:23:24 Turn Off Cooling
2026/04/15 02:23:24 [Guide] Stop Looping
2026/04/15 02:23:24 Stop Tracking
2026/04/15 02:23:42 Mount GoTo Home POS
Log disabled at 2026/04/15 02:23:42
I tried two more power configurations, a 12v 10a power supply with a y-splitter so I could run one cable straight to the camera and one to the mount, bypassing the power pass-through in the mount. I'd prefer to use the power pass-through in the mount, but it may not be enough to power the Air camera stably enough. The camera REALLY did not like this arrangement, it had near constant disconnects of the main imaging sensor, the EFW, EAF, and CAA (but strangely kept the guide sensor connected and the mount). So I disconnected that and switched to my EcoFlow River 2 Max, running a cigarette plug (12v 10a ouput) straight to the camera and then a separate DC 5.5x2.1mm power cable from the DC outlet on the battery to the mount. I was able to run a full plan session with no premature exposure failure issues with this configuration, but I was having a really unstable app experience with both my Android smartphone and an iPad mini. Sometimes it would fail to connect to the camera, sometimes it would stop responding, when I finally got it responding and tried slewing to M101 it wouldn't "find" enough stars to platesolve even though there were tons of stars in an exposure and it could "detect" a fwhm/star size from a single exposure. So I parked the mount, restarted the camera again, and after 2-3 restarts it did start acting more normally.
This is just becoming such a battle to get the camera to operate normally. Seems like I had none of these issues before moving to version 2.5.
