I am having great difficulty with the ASI1600MM ASCOM driver in The SkyX. I'm running Windows 10, Ascom 6.2, the latest daily build of The SkyX, and the latest Ascom driver from the ZWO site. I am trying to use the camera for autoguiding in The SkyX.
I am running the camera under the Autoguiding tab. I can find the camera and set it up OK, but when running continuous 1 second exposures the camera will stop downloading the image to the screen and hang after a random number of images have successfully been downloaded. I need to actually disconnect and reconnect the camera USB cable to bring the download function back. It will run again for a while and then stop and hang. This occurs while connected to either USB 2.0 or USB 3.0, although USB 2.0 seems more stable (i.e., takes a longer time to fail). This even happens when I reduce the frame down to a 1/4 sub-frame and 4X4 binning.
Some other funny stuff that may be of help:
While I can adjust the USB speed slider under the Ascom driver properties menu, it always shows that the value has returned to the default when I leave and re-enter the properties menu.
The camera immediately hangs at the image download if I select an exposure of less than 1 second. 1 second or greater exposure time will work (at least until it hangs as discussed above) but 0.9 second or less will immediately hang on the first image.
Any help would be appreciated.
Thanks,
Rich
