hi does the asi 1600 work with 1.25" filters /wheel ok or does it need larger filters thanks
yes, our 1.25" EFWmini would support up to F5 scopes
https://astronomy-imaging-camera.com/products/accessories/efw-mini/
Sam@ZWO For ZWO ASI1600MM, can I use with it EFW with 36 mm LRGB and narrowband filters, so that if I will buy camera with larger sensor in future I can use with it too?
Yes, you can use 36mm LRGB and narrowband filters with ASI1600MM Pro. You can also use this EFW and these filters with larger sensor.
