In case it helps, here is some additional information:
2017-03-31T00: World Coordinate System is enabled. CCD rotation must be set either manually or by solving the image before proceeding to capture any frames, otherwise the WCS information may be invalid.
2017-03-31T00: Setting frame buffer size to 1272704 bytes.
2017-03-31T00: UpdateCCDFrame ASISetROIFormat (1304x976, bin 1, type 0)
2017-03-31T00: ISNewSwitch->SetControlValue 6 40.00
2017-03-31T00: ISNewSwitch->SetControlValue 4 95.00
2017-03-31T00: ISNewSwitch->SetControlValue 3 52.00
2017-03-31T00: ISNewSwitch->SetControlValue 0 350.00
2017-03-31T00: ISNewNumber->set ctrl 2: 50.00
2017-03-31T00: ISNewNumber->set ctrl 0: 350.00
2017-03-31T00: setupParams ASISetROIFormat (1304x976, bin 1, type 0)
2017-03-31T00: The CCD Temperature is 0.000000
2017-03-31T00: Supported Video Format: ASI_IMG_RAW16
2017-03-31T00: Supported Video Format: ASI_IMG_Y8
2017-03-31T00: Supported Video Format: ASI_IMG_RGB24
2017-03-31T00: Supported Video Format: ASI_IMG_RAW8
2017-03-31T00: CCD ID: 0 Width: 1304 Height: 976 Binning: 1x1 Image Type: 0
2017-03-31T00: setupParams->set USB 40
2017-03-31T00: Control #18: name (Cooler on), Descp (turn on/off cooler(cool camera only)), Min (0), Max (1), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Control #17: name (TargetTemp), Descp (Target temperature(cool camera only)), Min (-40), Max (30), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Control #16: name (CoolPowerPerc), Descp (Cooler power percent), Min (0), Max (100), Default Value (0), IsAutoSupported (False), isWritale (False)
2017-03-31T00: Control #15: name (Temperature), Descp (Sensor temperature(degrees Celsius)), Min (-500), Max (1000), Default Value (20), IsAutoSupported (False), isWritale (False)
2017-03-31T00: Adding above control as writable control number 14
2017-03-31T00: Control #14: name (Mono bin), Descp (bin R G G B to one pixel for color camera, color will loss), Min (0), Max (1), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 13
2017-03-31T00: Control #13: name (HighSpeedMode), Descp (Is high speed mode->No 1->Yes), Min (0), Max (1), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 12
2017-03-31T00: Control #12: name (HardwareBin), Descp (Is hardware bin2->No 1->Yes), Min (0), Max (1), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 11
2017-03-31T00: Control #11: name (AutoExpMaxBrightness), Descp (Auto exposure maximum brightness value), Min (50), Max (160), Default Value (100), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 10
2017-03-31T00: Control #10: name (AutoExpMaxExpMS), Descp (Auto exposure maximum exposure value(unit ms)), Min (1), Max (60000), Default Value (100), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 9
2017-03-31T00: Control #9: name (AutoExpMaxExp), Descp (Auto exposure maximum exposure value(unit second)), Min (1), Max (60), Default Value (30), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 8
2017-03-31T00: Control #8: name (AutoExpMaxGain), Descp (Auto exposure maximum gain value), Min (0), Max (600), Default Value (300), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as writable control number 7
2017-03-31T00: Control #7: name (Flip), Descp (Flip: 0->None 1->Horiz 2->Vert 3->Both), Min (0), Max (3), Default Value (0), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as auto control number 4
2017-03-31T00: Adding above control as writable control number 6
2017-03-31T00: createControls->set USB 40
2017-03-31T00: Control #6: name (BandWidth), Descp (USB bandwidth percentage), Min (40), Max (100), Default Value (50), IsAutoSupported (True), isWritale (True)
2017-03-31T00: Adding above control as writable control number 5
2017-03-31T00: Control #5: name (Brightness), Descp (Brightness(offset)), Min (0), Max (240), Default Value (1), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Adding above control as auto control number 3
2017-03-31T00: Adding above control as writable control number 4
2017-03-31T00: Control #4: name (WB_B), Descp (White balance: Blue component), Min (1), Max (99), Default Value (95), IsAutoSupported (True), isWritale (True)
2017-03-31T00: Adding above control as auto control number 2
2017-03-31T00: Adding above control as writable control number 3
2017-03-31T00: Control #3: name (WB_R), Descp (White balance: Red component), Min (1), Max (99), Default Value (52), IsAutoSupported (True), isWritale (True)
2017-03-31T00: Adding above control as writable control number 2
2017-03-31T00: Control #2: name (Gamma), Descp (Gamma), Min (1), Max (100), Default Value (50), IsAutoSupported (False), isWritale (True)
2017-03-31T00: Control #1: name (Exposure), Descp (Exposure Time(us)), Min (32), Max (2000000000), Default Value (10000), IsAutoSupported (True), isWritale (True)
2017-03-31T00: Adding above control as auto control number 1
2017-03-31T00: Control #0: name (Gain), Descp (Gain), Min (0), Max (600), Default Value (200), IsAutoSupported (True), isWritale (True)
2017-03-31T00: CCD is online. Retrieving basic data.
2017-03-31T00: Setting intital bandwidth to AUTO on connection.
2017-03-31T00: Attempting to open ZWO CCD ASI224MC-Cool...
