Hi,
I have just purchased an ASI120MM, the USB2 version but cannot get it to be recognised by my PC.
I am in contact with the supplier about this issue but require further information as to what is possibly the problem with the camera.
I already have an ASI224MC camera with is attached and working perfectly, so all ZWO software and drivers are already on my system.
When I attach the ASI120MM to my USB2 port it shows in Windows 10 Device Manager as 'Unknown Device' with 'code 28' see attached image Cam4.png:
Now if I click on the Device Propterties Details tab I can see the Device Instance Path & straight away I can see that the 'D.I.P' of the ASI120MM is incorrect, see image Cam5.png:
it is showing 'USB\VID_04B4&PID_8613\5&1B0F3F2&0&4'
and from my research the Vendor ID of 04B4 is for Cypress Semiconductors & the Product ID of 8613 is for Cypress USB Open Host Controller.
Surely the 'D.I.P' should be showing as: USB\VID_03C3&PID_120A\....... etc
The supplier has asked me to perform various tasks in a failed attempt to get the ASI120MM working, namely switching off my Anti-Virus software, which is Windows Defender, which I did and then ran the driver install, this did nothing, no changes.
I have tried all these steps on 9 different PCs up to now all with exactly the same outcome.
They then pointed me to the ZWO Firmware Update Tool, which sounded hopeful but alas did nothing because the ASI120MM had to first be recognised by Windows in order to be found by FWupdate.
See here where I have my 2 cameras connected ASI224MC & ASI120MM:
FWupdate only shows 1 device connected and that is my ASI224MC, the ASI120MM is not listed.
On top of this I have tried to manually update the driver for the ASI120MM in device manager by choosing:
Update Driver > Browse My Computer for Driver Software > Let me pick from a list...
I select 'Imaging Devices' from list then ZWO as manufacturer and finally ZWO ASI120MM Camera as the model & click OK, then I get this warning:
see next post.....
