Hi Sam,
Maybe I'm doing an extra step with the flats that maybe I should not be doing for these tests. After I Debayer I perform a Automatic Background Extraction, (ABE), in PixInsight. Your images that you're showing only appear to had been debayered. Maybe that is where the confusion is.
From what you're saying, the Flats I sent both from the ASI071 camera and the Atik 383 Camera look good?
I'm still not sure about the red cast I get when processing the images but for now the only way to know is to, when the weather permits, take some new images along with Flats, Bias, and darks to see it everything is cleared up.
Two questions:
1. Do you have a recommendation on what ADU value I should shot for as well as exposure times for the ASI071 Camera when taking Flats? I've always aimed for 30,000 but I read where other folks shot for something around 15,000 for the ASI071 Camera.
2. Bias - Any recommendation on the time? I've always used 0.01 seconds. But again I've read where folks take bias frames at 0.1 seconds.
I still don't fully understand why I never had any of these issues when I was using ASI071 but have them in the ASI071 Pro. I don't really care at this point as long as I can start imaging again and get good results.
Thanks Sam for helping me on this.
Kind Regards,
Mark
