PA not working on my Celestron mount.
I have a new CGX mount and not having any success polar aligning the mount (not working for my AVX mount either).
I have an ASI AIR PLUS that I've had for quite some time,
I deleted the app on iPad (late version), and uploaded the latest version of ASIAIR (Mini, 4th edition).
Aside from PA, everything else with the app works fine.
Prior to PA, I'll conduct a successful Plate Solve, and click on the "Sync Mount" option.
I then get a message "Sync Out of Range-ASI AIR doesn't support to sync the mount within 5 degrees of the NCP". I click "dismiss" and proceed to PA.
When I attempt to PA, the mount will slew to the west, approx 60 degrees,
I get the attached screen shot and the PA process won't proceed any further, so I need to cancel out of the process.
I manually align the and PA mount and have no guiding issues.
I used to be able to PA my AVX mount but no longer can, nor can I PA my new CGX mount.
Any recommendations, or will the PA function not work with Celestron mounts.
Thanks in advance,
Steve
