From Thailand.
ASIAIR and ASIAIR-Pro
iPadAir
CEM70G mount
ASI294MC-Pro
ASI120MC-S
ZWO Mini EFW
There is a problem connecting CEM70G and AIR Pro.
The CEM70G is the latest equipment and the firmware is also the latest.
The built-in USB-HUB of CEM70G is USB 3.0 and is also powered.
ASI294MC and ASI120MC-S are connected to USB-HUB @ CEM70G.
(1) When ASIAIR-Pro's USB3.0 Port is connected to CEM70G's USB3.0Port, the problem of not recognizing CEM70G's USB device
-Connect the output side USB3.0 port of CEM70G and the USB3.0 port of ASIAIR-Pro.
===> ASIAIR-Pro does not recognize two ASIC CDs and Mount of CEM70G. It may be recognized about once every 20 times. However, even in that case, Mount repeats ON / OFF intermittently.
Not completely usable
(2) When ASIAIR-Pro's USB 2.0 Port and CEM 70G's USB 3.0 Port are connected The CEM70G connected device is recognized, but communication with the mount is unstable.
===> ASIAIR-Pro recognizes two ASIC CDs and Mount of CEM70G. However, even in that case, Mount repeats ON / OFF intermittently.
ASICCD works fine, but mount control is almost impossible.
Regarding the above USB 2.0 Port connection, I tested it with ASIA Ir V1.0, but the situation is the same.
I tested it with the same connection configuration using NINA + PHD2 on a Windows 10 PC, but it can be used without problems for all CCDs and mounts.
However, in the case of Windows 10, it was necessary to turn off all the energy saving settings of USB3.0 HUB on the PC. If this was not done, the entire USB device would repeatedly turn on and off.
Thank you
Taro
Please investigate immediately
