ASIAIR Pro
So far it is Working Great.
The only Wish List I would like to see is to add the Sky-Watcher EQ6-R Pro EQ Mount's USB Port on the Mount Support.
This way you do not need to connect it to the Hand Controller and have it connected with another cable.
Still I really wish I could just use my Windows 10 Laptop and not have to use my iPad.
Hardware:
Sky-Watcher EQ6-R EQ Mount + QHY PoleMaster EQ Mount Polar Alignment + William Optics Zenithstar 103 APO & WO Flat6AIII + Slide-base UniGuide 50mm + ZWO ASI174MM Mini Monochrome Guide Camera and with a ZWO EAF
Explore Scientific 127mm f/7.5 APO FCD100 ED Triplet Refractor + ES 3" Field Flattener/0.7x Focal Reducer + Slide-base UniGuide 50mm + ZWO ASI174MM Mini Monochrome Guide Camera and with a ZWO EAF
Camera ZWO ASI183GT Camera ZWO LRGB Filter Set - 31mm Unmounted - LRGB-31 + ZWO 31 mm H-alpha & OIII Filter
Not Tested.....
Explore Scientific iEXOS-100 PMC-Eight Equatorial GoTo Mount System + DSLR EOS Rebel T6i + ZWO 30 mm f/4 Mini Guide Scope + ZWO ASI290MM Mini Monochrome Guide Camera
