Tried shooting another target last night (first time in a month) and I'm STILL having mount disconnections when using the ASIAir Plus. Any other software, controller is fine but Plus shows it is connected to the mount (CEM70), but when I try to slew the mount, or make any changed I get the message "Mount not connected". This has been going on since I( bought the ASIAir Plus two months ago.
I have replaced the mount's power supply, backed off the Plus' firmware then reinstalled, turned off all power and restarted, rebooted each connection, and everything I can think of, but all that was as useless as this ASIAir Plus. I'm an I.T. guy and performed every troubleshooting trick I could think of, nothing helped. Last night I kept fiddling, rebooting and trying different things over two hours till the mount was finally detected. I was able to image for an hour before the mount disconnected. I was able to reconnect and get several hours in. After imaging I clicked on the ASIAir app for the mount to go to the Home Position when the mount showed it was disconnected. That was four hours ago. I'm still not able to detect the mount. Even when the Plus' App shows the mount is connected and I click to turn the power on (for the mount) the app displays "No mount connected".
ZWO, I have been putting up with this for two months now. I have sent in logs (two today, with photos) and not sure what to do.
I know I'm not the only one having this problem (a Google search shows that) so please at the least reply to this and tell me to F off if you're not going to help. At least then I'd know you see my multiple requests for help.
Thank you,
L
