Hi. I am interested in using your EAF with my Baader Diamond Steeltrack focuser - can you tell me whether the current version of the EAF allows this, or do I need to wait for a custom adapter? Do I need to swap the coarse and fine focuser knobs (currently on RHS) to the other side of the Steeltrack?
I have an ASI294 MC Pro as my main imaging cam. This has 2 USB 2.0 hub sockets on the back panel. Can I plug the EAF (and indeed my ASI120MM guide cam) into the USB2.0 hub sockets on the ASI294, so that the 294, the 120 guidecam and the EAF all use the main USB3 cable from the 294 to my laptop?
Can I put a splitter lead on the 12v supply to the 294 so that I can use the same supply for the EAF? The supply is 12v 5amps.
Many thanks
Paul
