@tech@zwo#54700
Every time I made those attempts the goto functionality worked perfectly, but I will re-check that before the log thing.
Where do I find the log, and how I upload it?
    Azaqui hi, you can find the "submit" in about settings page. Please submit the log as prompted. After that, don't forget to tell me the email. Thank you very much~
    @asiair@zwo#54730
    Ok finally got clear skies, went through the procedure and uploaded the logs.
    I did the guiding calibration as per your specs - x1 rate 2000ms cal step.
    How do I tell you my email (don't want to just post it on the forum)?
      As a side note there is no difference between different slew rates, and the distance between consecutive steps can decrease....
      • w7ay replied to this.
        Azaqui As a side note there is no difference between different slew rates, and the distance between consecutive steps can decrease....
        Did you check if tracking was on when you observed the East-West distance decreasing? It is the Tracking switch in the Mount Settings window.
        Tracking has to be on when you are guiding (or calibrating guiding).
          @tech@zwo#54808 Done!
          Once again, thank you for looking into that!
          16 days later
          Are there any updates on this weeks later?
          5 days later
          Guys, this is no way to do customer support, I spent quite a lot of money on your gear
          6 days later
          @A
          @tech@zwo#54808
          Any updates?
          I still cannot use my ASIAIR because of no tracking…
            Azaqui Hi Azaqui, Sorry, our devs are working on this, if there are any updates, we will update here.
            Thank you very much for your patience and support.
            2 years later
            I know this is an old thread, but I am having a similar issue, has this ever been resolved? Has anyone gotten Guiding with the Nexstar mount and ASI Air working?
              SFA80Wu9 Could you submit a bug report in the ASIAIR app for further analysis? thank you.
              Write a Reply...
