@asiair@zwo#54730
Ok finally got clear skies, went through the procedure and uploaded the logs.
I did the guiding calibration as per your specs - x1 rate 2000ms cal step.
How do I tell you my email (don't want to just post it on the forum)?
Azaqui You can submit a ticket here to tell us your email address. https://support.astronomy-imaging-camera.com/ Choose 'product' tab
As a side note there is no difference between different slew rates, and the distance between consecutive steps can decrease....
Azaqui As a side note there is no difference between different slew rates, and the distance between consecutive steps can decrease....
Did you check if tracking was on when you observed the East-West distance decreasing? It is the Tracking switch in the Mount Settings window.
Tracking has to be on when you are guiding (or calibrating guiding).
w7ay
Yep, tracking was on!
@tech@zwo#54808 Done!
Once again, thank you for looking into that!
Are there any updates on this weeks later?
Guys, this is no way to do customer support, I spent quite a lot of money on your gear
@A
@tech@zwo#54808
Any updates? I still cannot use my ASIAIR because of no tracking…
Azaqui Hi Azaqui, Sorry, our devs are working on this, if there are any updates, we will update here. Thank you very much for your patience and support.
I know this is an old thread, but I am having a similar issue, has this ever been resolved? Has anyone gotten Guiding with the Nexstar mount and ASI Air working?
SFA80Wu9 Could you submit a bug report in the ASIAIR app for further analysis? thank you.
