I'm also unable to reset the home position in the ASIAIR Pro. I have a CGEM II (hypertuned). I followed all the above instructions, that is, with AIR off, I do a 2 star alignment of the mount (plus with 3 calibration stars), I use the mounts Utilities/home/goto which brings me back dead centered to Polaris. I then power up the AIR, and connect the USB to the handheld of the mount. Then on my iPad, in the AIR App I connect everything - mount and cameras. I always try to sync the App to the mount...always fails. I then use the App's goto. which moves to about 30 degrees east. I go back to the handheld goto which goes to dead center to Polaris. I've made sure I'm directly connected to the AIR wifi (and not my extender) for this testing. Unlike Radders76 above, after AIR/Preview/Goto a target the Home problem does not resolve.
so how do you successfully sync AIR App to the mount? maybe this would help?
