ASIAir also already embeds the filter name in the FITS header, which is extremely useful when processing. Filter is a standard 8-character field in the FITS header. I'm just asking to be able to specify what gets embedded in the header and the filename.
PixInsight for example automatically sorts the files into different processing groups based upon type (Light, Dark, Flat, etc.) exposure duration and filter name. I don't want to lose that.
When I do a capture using Ekos I can specify those filter names. ASIAIr however limits me to a small list of choices that doesn't include common filters.
See my example below where you can see I have Light subframes shot in R, G, B, Ha, Oiii, Sii, and "8" because I couldn't specify the UHC filter I used. I have similar flats from that session as well. Also "8" looks a lot like "B" on my screen so that could lead to operator error. 🙂
As noted, now that ASIAir supports video for planetary imaging I will have a similar problem where I can't specify my CH4, UV, or either of my two different wavelength IR filters (656nm and 850nm). I'd love to be able to type in "IR850" in ASIAir.
Also my related post about saving different equipment profiles in ASIAir comes into play here. I switch between two different EFWs and cameras for DSO vs Planetary imaging. Editing the filter names each time I switch is not great.
