achim2205 Hi, their algorithms are almost identical. It's just that some optimization can't be done in live stacking.
ricardinho We'll consider your suggestion, thank you!
Hello, just a few suggestions for the Fits-Header created by ASIDeepStack:
achim2205 Thank you very much for your suggestion. We'll take it into consideration!
what's new for ASI Img? Thanks
bafio Hi, bafio! There are no significant features added in ASIImg. Change log almost completely presents its change. Thank you!
Where can we download the manual?
Bflanagan skipper71 Hi! The manuals are embedded in the respective softwares, click Help.
I updated to 1.4, but now it cannot find my ASI120mc-s. Does not show up in the list.
Danshep Hi😄! Are you sure that it works well in 1.3.2(You can try again)? Now can you hear the USB device change tone ? We need your SDK log to solve it. Thank you!
I'm with Bflanagan, where can we download the manual?
I just downloaded ASIStudio 1.4 on macOS 10.14. Congratulation for the renewed interface. But ASIDeepStack crashes systematically. It even crashed my computer.
jcj2249 We are sorry for that! ASIDeepStack still needs to be improved. At present, if stack too many images, it will cause a crash. Try less images~
jcj2249 I just tested that ASIStudio 1.4 on macOS 10.14 crashes if more than 12 lights are used It creates the result (Light_AutoSave_Stack.fit) and crashes.
I have a problem with my 294MC, ASI Img don't save the frames with exposure time is over 120sec. I reported that at the technical help, i'm waiting...
bafio Did the exposure fail?We need your SDK log to solve it. Thank you!
jcj2249 How many calibration frames did you import? In other words, what's the size of all files imported? What is the memory size of your Mac?Maybe, ASIDeepStack needs more memory. In the future we may be able to reduce the hardware requirements.
Can ASIDeepStack perform frame alignment while stacking?
jmlattis Of course!Please pay attention to the tips prompt during the stacking process.
@asistudio@zwo#46336 Beautiful software that you have been using since you first released it. When does the plate solve function?
piero65 This is in our plan, the specific time is still uncertain. Thank you!
