darkmatter You are absolutely right and I forgot to include that in my suggestion. Indeed, the frame overlap (perhaps in % ?) needs to be configurable as well.
The overlap may be hard to calculate properly when imaging close enough to the celestial poles. For instance, for my 5x3 degree setup, when imaging close to the north celestial pole, the south sides and corners of the image will have significantly less overlap than then north sides and corners.
