Timbo From what I know. In the next app update the problem will be resolved.
If you are willing to use Beta software, ZWO has already posted the Beta v1.7 on Apple TestFlight (and I am sure on Android too). You should be able to test if you can connect to the mount without taking the mount outdoors.
Be sure to back up your microSD card, so you can revert back quickly in case the Beta is not working for you. The Beta app will update the firmware to 8.46. The old v1.6.2 app will not work with this firmware.
