- Edited
w7ay The flat ribbon cables are useless for high speed data.
Apart from the one that failed, I really haven't seen any problems with using the ZWO USB 3 flat cables.
I've run them at 200 FPS for planetary without dropped frames and for 120 second subs no problems. I can't put my finger on any problems the ZWO flat cable has caused in normal operation. I like that the cable is very light and flexible and I do coil them up when they are too long.
Sure, they are not "Space Rated" or made from "Weapons Grade" copper, but nothing on, or under my telescope is perfect.
For me, time and money are limited, so before I spend either on telescope or mount improvements, I ask myself one question, "Will this improve my final images?"
So, if I spend the time finding the "perfect" cable, and spend the money on it and shipping, will I get better subs?
Steve.
@tech@zwo I'll happily use a replacement cable.
