JerryK Sorry for delay. Yes ASIAIR works with EVO. You may need to create a new OS card depending on the USB hardware in your mount (see EQ6-r forum). There may be a way to connect wifi to the mount, but I wouldn't bother. The EVO wifi has dropouts which don't play nice with other software. USB is much more stable in my opinion.
EAF works fine on my c8. You will want to increase the default step size. Don't worry about guiding until you move to EQ setup (either via wedge or GEM mount). A guidescope is ok with sct, but you will be susceptible to mirror flop and flexure (max 2 min exposures from experience). OAG tend to be better.
Edit: You will also not need starsense with ASIAIR. ASIAIR automatically plate-solves and updates the mount pointing model at every target. It works really well from experience. Even if you have a REALLY good pointing model, the EVO does not have encoder so slew can still be inaccurate. Plate-solving works every time, I don't even bother aligning carefully before my first target (1 point alignment in the ballpark of target).
