Has this been fixed? I am using a Samsung A tablet and a Google Pixel 4a. Neither can automatically set the location of the ASIAIR Pro.
It's been awhile since this was reported. Any update on a fix? Quite a few users using Android. Location details fails for me on Pixel 5 Android 12. Samsung Tab A7 Android 11 using the Asiair Plus.
Not fixed as of yet. I still have this issue with my Android devices. I'm sure it'll likely be in the next patch.
Or not. Testing the newest version and it's still not updating.
@asiair@zwo#50499 Are there any updates on this? It wasn't fixed in the newest test version.
@asiair@zwo#50933 Update please?
Still ongoing. Update?
also waiting 🙁
would love it if this got fixed! Any updates?
Pixel 4a works fine for me with the ASIAir Pro.
In the newest beta, im getting "Locate Failed: Code=4" when attempting to refresh location. Does that help anything?
shadowangel Hi Try the following:
I'm also getting this error on my Android Samsung Fold 3. I'm not understanding the instructions on this. Turn off the wifi on our phone then back on, then we're supposed to connect to our home network router? Can you please restate the instructions more clearly.
I'm having the same problem with S10+ and S22ultra. disconnecting from asiair's wifi; locating under 4g/5g and reconnecting to wifi sometimes work sometimes no. Is very frustrating missing such a basic function. Same error happens on latest beta too
Could ZWO give us an answer about it? this problem has not been solved in the beta, when will it be solved?
FYI, in v2.0, we will fix this problem thru a new API. Thanks for your understanding.
@ASIAIR@ZWO#58156 Hi, the latest update 2.0 sitll has this problem, will it be fixed for this version? Thank you.
jcapurro Working on it.
I have received my new ASIAIR plus, ZWO mini guide scope and color camera. I Connected the ASIAIR to my phone Samsung Galaxy A42 5G thru Wifi. That all works. I then select my mount {Celestron AVS} the ASIAIR software does not fill in the GPS data. I need to steps to correct this issue.
I'm running a Google Pixel 7 Pro and the latest asiair plus and I can't get it to work either.
We assume v2 API didn't help?
Any further updates please?
