seanh The EFW MINI has a different thread size than my 183mc
Are you sure you have an EFWmini wheel? Mine has a M42 hole for the camera end.
Remove the black T2 ring that is the normal flange that comes with the 183MC Pro. This exposes a M42 male connection. This picture shows the ASI183MM pro, but your 183MC pro should have the same flange.
The Mini EFW has an M42 female hole.
Screw the exposed M42 thread of the ASI183 into the female threaded hole of the EFWmini; there is enough clearance to not rub against the carousel:
