Hi Kings,
I updated my note above, to be more complete.
Only the ASIAir needs to connect to the handset (HBX), not the phone which is Wifi connected to the ASIAir.
The HBX Wifi is an open connection, so no password is required.
The HBX Settings menu contains the WiFi Option to restart the module or factory reset, which may help in case it got somehow confused. (BTW, the password 12345678 goes with ZWO products, not iOptron.)
I confirm that there is no USB cable involved, nor from the HBX, nor from the mount, which I find very convenient.
BTW I had a very, very hard time to unplug the USB cable that came with the mount once plugged into the HBX. I tried several other USB cables, which plugged and unplugged much easier, but with none of cables I could get a serial connection with the ASIAir.
Somewhat off-topic: I also use this Station Mode for other mounts with WiFi, like GM1000, obviously with different IP and Port. Saves a cable.
Clear skies - Huib
