Ah, OK folks, you can run ASIAIR 2.0.0 Beta on macOS, by first downloading TestFlight into the Mac (not the Mac TestFlight for beta testing Mac programs, but iOS TestFlight :-). Then download the ASIAIR beta using TestFlight.
(Moon is appearing from behind clouds through the trees (time to play Dvořák's Song to the Moon :-). Bright star is Vega with a slightly tilted Northern Cross to its left.)
By the way, one thing to note is that ZWO did not make the app's window sizable. If you are running other iOS apps on the Mac, you will find many, if not most, of them let you resize the window. The ASIAIR app does not.
