- Edited
crackout Noted, will optimize. Thanks for your feedback.
@ASIAIR@ZWO#59513 Excellent!
w7ay Sure, I type it manually. I connect it to my samsung galaxy S10+ that has GPS. So I installed an app that gives me the coordinates to type them in the Asiair. But I didn´t have this issue with the Asiair pro. This issue is for android and it is not new, it's been reported long ago. Hope it's fixed in this release. Thank you.
I heard, ASIAIR has problems with guiding of the new Sky Watcher Adventurer GTI, see https://www.facebook.com/groups/StarAdventurer/posts/3383039848644321/?comment_id=3386647971616842&reply_comment_id=3386724864942486 Can this be fixed in the final release of 2.0 ? It wish it will, I've lost three nights in trying to find out what is wrong. @ASIAIR@ZWO#59513
@ASIAIR@ZWO#58479 Hi, just installed and for android doesn't get the coordinates from the phone GPS.
Hi! I can't login in Me tab on MacBook Pro M1. On iPhone and iPad everything works fine. Checked traffic with proxyman.io and server responds with proper JSON body including access_token and all other stuff like profile info, etc. Moreover, I discovered security issue: you're sending password in plain text and these days it should be at least SHA1 hash and do the comparison on server side. It's not that difficult to implement using Apple's CommonCrypto framework. I've sent feedback using TestFlight already.
Can you fix the Live Stacking Histogram reset after each new stack comes in. Seems it has to be re-adjusted after each new image. That is not good at all and no fun.
scopesnc Noted. Will try to reproduce and fix it.
I am issuing a bug here. Probably already known. Skywatcher Virtuoso GTi mount driver does not have any tracking available to set on the "camera" like Skywatcher AZ/GTi/SynScan Wifi Driver does. I can not use the SynScan Wifi driver as a substitute as there appears to be some differences.
@ASIAIR@ZWO#59513 Here's a screen capture of the saving progress. It takes 15 seconds to save an image in Preview mode.
https://www.dropbox.com/s/ls8s839pvpufhvd/RPReplay_Final1666027769.mov?dl=0
Hello everyone, the new public beta version has been released~
[2.0-10.40] - 19/10
Good, in the update 2.0.9 and 2.0.10 when entering the application I get the message "The network is abnormal, please try again" and then when I click "Enter Device" I click "NEXT" and it closes the application, has it happened to someone else? the tablet has only 2gb of ram, but until version 2.0.6 it worked perfectly for me, thank you very much.
avpinedo Thanks for your feedback, which model of your tablet and the OS version?
avpinedo Search and read the new hardware requirements for the ASIAIR app release 2.X versions after October 1st?
Thanks for the continued development. Now I have an ASIAIR, AM5, several cameras from you and the EAF all for my travel rig, I find the whole setup so much easier to go out and just start imaging! Now I only struggle with my observatory and my Paramount MEII and ASI1600mm. Any prospect of supporting Paramount mounts in the future? If so I can then buy another ASIAIR for that setup too.
I’ve really been enjoying the v2 beta releases over many cloud-free nights. I’ve been having trouble with the official bug reporting tools, so I’m writing this here. Unfortunately the last couple of releases have introduced some new problems for me. First, am I the only one that is now restricted to a maximum of 30 second subs? If I try a custom time’ like 300 seconds, I get an error message that says only exposure times between 0.001 and 30 seconds is allowed. I was some how able to make the plan with 300 second subs. The plan shows the correct estimated total duration for each target. The logs lists 300s subs the, but the image time stamps show that each is only 30 seconds. So for 60 subs, it will capture sixty 30 second subs in only 30 minutes. The the system waits for the time that 60 five minute subs would take (5 hours) before starting the next target. One other annoying, but much less critical problem is that when I hit the stop button Autorun, Live, or Plan, the exposure in progress doesn’t stop or get canceled. Both of these problems started with v2.0 (56) 10.37 and persists on v2.0 (58) 10.40. Thanks for your help.
