jcapurro I just try and it doesn't get the coordinates for android, still gives an error 4 on location..
Does your Android tablet have a GPS unit in it?  On iPads, only the WiFi+Cellular models have built in GPS.  Check the documentation that came with your tablet.
If you don't have GPS, the tablet will at least needs to know its own location somehow (often by using "Assisted GPS" through WiFi).  If your tablet has no GPS and it is connected to the ASIAIR's hotspot, then it cannot get coordinates (ASIAIR does not have an option to get location from a mount's GPS).
If there is no way to get location from the tablet, you have to enter it manually into ASIAIR.
Notice that when you first launch ASIAIR, it will show a setup window, with selection for camera models, mount model, EAF, EFW, etc.  On the left part of that window, you should be able to find the location data.  Type those in manually.
