I'm liking the new number entry keypad.
Just noticed a possible bug. If you don't refresh the target, the coords can be out of date. Was looking at Jupiter a couple of days ago and it was still set as the target tonight but the goto was way off. Reselected Jupiter and the goto was bang on.
    @ASIAIR@ZWO#59008 in the mount controls widget, just says Jupiter.
    I guess the coords are fixed at the point you select the object.
      I have two very similar setup, one with EQ6-R Pro with USB included and one with EQ6-R Pro without USB.
      I upgraded to latest test version V2.0 (48) and one of the AsiairPro does not connect anymore to the mount without USB with Pegasus Astro EQdir cable. The other mount is working fine. I made some test, and the mount is working via the hand controller in PCdirectMod but not with EQdir cable. Do you have any suggestion how to solve the problem?
        balasi Others reported this issue. Please upload the log so we can try to fix it.
        Could it be possible to allow the gain of the camera to go above 300 ? Also , in live mode it will be great if the user can adjust the colours or have more flexibility. This will allow for a great eaa system
        So far so good. Very nice upgrade. The only issue was smaller fonts for my iPhone. So, I used it on my iPad. On my iPhone I reverted to the working version of ASiair.
        I installed and tried an entire imaging session for Cave Nebula (C9). I did not notice any bugs. I’ll post a video on YouTube today.
          @ASIAIR@ZWO#58893
          Can you try on Mac that never load a beta. I think there is a problem on "naive" Mac.
          Like wrote by @w7ay Notice that the Asiair app is listed as "IOS Only Apps" in the left hand panel on my Mac.
          On him Mac it was simply Apps.
          I like the idea of @jrrjrr "I think ZWO changed some sort of permissions on the past few beta releases, but that people who have been updating from betas going back a month or so ago, or earlier, are somehow "grandfathered" from this recent exclusion. When ZWO tests updating on their M Macs, they are probably "grandfathered" as well. I bet if they tried the current beta on a Mac that has never seen a beta before, they'd be able to reproduce this bug."
          What do you think about a permission problem on Mac that never load Beta.
          Thanks for reply
          Best
          Thanks for the update
          I don't understand this :
          @ASIAIR@ZWO#58479 Added Az/Alt Display in Mount Setting
            And btw i still have no tracking when i use the AZGTI in Alt Az mode with the alt az wedge driver like i had with stellarmate. (Goto and plate solve is ok but no tracking) Do you plan to fix this ?
            Can you please install the last indi driver for the AZ GTI in native Alt Az mode with tracking ?
            Any plans to fix yet the incorrect orientation of the main app. ASIAir is a landscape based app.. why is the opening screen still portrait. All iPads are landscape, there should be no portrait orientation.
            this really is confusing why you designed it like this.
            Also the Chinese characters are back on the US version of the app
              Hi all i don't know if this question is writed on other post before, but with 2.0 beta i see that gain of camera, i have asi 2600mc, for all start of app, goes default to low. Although at every start I put it back in median alias gain 100. It seems that the app does not memorize the last gain set.
              Kring Thanks for your feedback. We will try to adapt the iPad or Tablet UI more in the future.
