Dspital it’s there when DEMO is selected for the mount, It is not when I select Celestron NexStar/Advanced GT. No sync to mount button.
Yep, looks like another bug in ASIAIR. They need to look into it; I don't know why they are still refusing to respond to your initial message.
There is definitely a "set Location" command in the NexStar protocol, so the ASIAIR should be able to set it. This is from the NextStar documentation (the ABCDEFGH are the same arguments as in a GOTO command).
Your mount does not happen to have built in GPS does it? If if does, try turning it off to see what happens.
