Could you please add a naming option for filter other than from EFW? I use Hyperstar, which has a filter drawer. There is no way to distinguish subs with one filter from subs with a second or third filter.
viperduude that was already asked from me and is on the ToDo list as ZWO agreed
@ASIAIR@ZWO#60353 Hi, Thanks for replying. I've done this by switching the asiair plus on/off. Attempting again de connect just makes the app hang for me. Uninstalling version 2.0 and installing version 1.9.1 gives me a fully functional app. I've got to try a reset of the asiair but I haven't had the time yet. Cheers.
rodrigol Hi, I have reset the asiair+ wifi and managed to get the phone to update the firmware and connect properly. The problem persists with the tablet. Connecting directly works but going STA does not. I'm going to try switching off 5g. I'll report on this approach later.
Thanks.
Is ASIAir supposed to attempt to re-center an object during Autorun? I have not seen this before the latest 2.0 version. I was working on polar alignment (drift method) with a SkyGuider Pro and doing some test shots at M31. The Autorun stopped after the first frame and the ASIAir attempted to re-center M31. Of course this failed because the SGP is not a goto mount. I had to re-start the Autorun each time. Once I had the alignment dialed in and there was no dec drift the behavior stopped.
hughes I would like to know the same thing
Are the community map locations available in any other language than Chinese? Why does the community locations map always default to ZWO Home base?
Can we have an option to automatically „enter device“ upon launch? I don’t need the community features etc. It just adds another tap necessity.
Getting there would still be possible by using the „return“ button at the top left, if needed.
What is the "Astronomy Community"?
JohnD
johnpd
It's the web page you get when you start up the new version before entering the device.
johnpd New feature, for all astrophotographers over the world to share there imaging, chat with each others.
Hi The icons are displayed like this in the new app. Thanks for any help Samsung s5e tablet [model]() Android 11
sajjad there is no one to help
sajjad Please change the language to English to try again.
sajjad It's a bug. I will send you a bugfix version thru the email of your account, is that ok?
sajjad Thanks, the problem is solved with en language But is there a solution for Persian language users?
Would it be possible to add a mid tone slider to the histogram?
rodrigol Hi, the network reset and going 4g only did not work with the tablet. When enabling STA the tablet disconnects and never manages to reconnect. I've tried this on 2 Samsung tablets (Galaxy Tab S7 FE and Galaxy Tab S5). Version 9 worked OK. Thanks.
KF7DS ZWO says this was an ST4 error that was fixed in the latest beta 2.0.1. I have not yet tested.
@Tech@ZWO did the update went through review successfully? I was wondering that as I read here of people receiving it, though I still have none available on Android (Pixel 6a), at least here in Europe.
How long before we can see changes so that we can control the histogram colors individually like Sharp Cap allows??
Autofocus seems to be really struggling with the new software. Used to work perfectly. Is anyone else having autofocus problems?
