umasscrew39 Is there a way to set up two 7x2" EFWs so that the software does not get confused as to which filter wheel I am trying to use?
You can customize the name of a ZWO EFW by using one of the programs in the ASIStudio suite.
The following shows ASICAP after clicking on the Editor icon at the far right of the EFW name (a small "Edit EFW alias" window pops up):
This is what the EFW name looks like after entering "LSHO" into the "EFW alias" text field (it appends the alias within parentheses to the name stored in the EFW firmware):
See if this can help you distinguish between the two EFWs.
