Hi Tech@ZWO , I have a follow up question w.r.t the image you shared in last message. I have an OAG-L with m48 sensor tilt adapter (came by default) so I attached it to the telescope side (askar fra400 to it's 0.7x reducer with m48 male which forces us to use m48 tilt adapter on OAG-L.
Now coming to the camera side, I purchased an M54 adapter as (marketed as replacing efw) to attach it to my 533mc pro.
I got a 11mm T2 tilter as well following the recommendation in the pic.
Coming to my question, when I insert a filter into the M54 adapter as shown in pic, how do you expect users to remove it or even replace filters? It's not like a threaded one to simply untighten, then add/remove filters right? It has got screwed into OAG-L and T2 filter on both sides, which requires one to have allen keys handy making it damage prone as well to optics in between. Isn't that a lot of struggle? Very poor solution if you ask me.
