cpl42 how do you delete an entry?
Paul, as mentioned in my earlier reply to you... if you are using iPadOS or iOS, hold down your finger on the target item in question (in the graph region) and swipe your finger towards the left edge of the window (this is how macOS contextual menus -- right mouse button down -- are implemented in iOS/iPadOS).
In the case of My Favorites, the contextual menu consists of two buttons (on the right side of the target item).  One is Add to (that allows to you move a target to one of the other Categories -- like Focus Stars, for example).  The other is a Delete button, to remove that Target completely.
Pretty standard GUI element in iOS/iPadOS that you find with other apps too.  You might be familiar with it in the iOS Music app, for example.
How about making this application up there with the best of them?
ASIAIR will never be one of the best out there.  You need open sourced environments for that, where people knowledgable in astronomy, image processing, celestial navigation, good computer engineering and documentation, can collaborate.  Not to mention being able to support more than one company's products.  At best, ASIAIR will be easy to use, as long as you don't ask for something that is not brain-damagingly basic (like your need to edit a target's coordinates), and not needing to use devices that compete with ZWO's offerings.
