Kevin_A testing out each axis at a time until I find the best settings for each axis.
That is very good advice.
For everyone else, remember that when you are tracking a target, the RA axis moves constantly at sidereal rate though the different angles of the RA shaft. As time elapses, it would move completely through one period of the error curve in 430.82 seconds.
The declination axis is completely different.
If the mount is perfectly polar aligned (won't happen in practice), the declination axis does not even move. With imperfect polar alignment, the declination of the mount will make an error path relative to the constant declination in the sky. But this is typically a slow drift -- you can observe by turning the max declination pulse duration to 0 (in ASIAIR you cannot use zero ms; just use 1 ms), so that PHD2 is not controlling the declination axis, and you can watch the drift rate for your given polar alignment error. (That how we used to do "drift alignment" -- slowly adjusting the altitude and azimuth bolts until the drift flattens out.)
So, while RA is moving about 15 arcseconds per second of time, the declination will move very little, perhaps one arcsecond per second of time. Moreover, it will be moving back and forth, but centered about a fixed declination motor angle, and only make one cycle in one celestial day (23 hr 56 min) instead of the 430 seconds for the RA axis.
For the declination axis, the optimal max declination pulse is therefore usually much lower than RA axis. That is, if there is no flexure, and the RA axis is within a minute of arc or two of the pole.
How big and how small that error envelope is will depend on the actual declination angle, since the declination angle depends on the angle of the declination shaft. If you are lucky, the target's declination places the declination shaft at where the slope of the PE is lowest. If you are not as lucky, the target 's declination places the declination shaft at angles where the slope of the PE is highest. Again, it is not the amplitude of the PE, but the slope of the PE that matters.
I don't think ZWO gives plots of the periodic error of the declination shaft, otherwise you could pretty much predict where the favorable declination angles of your mount is. However, it is not a huge problem, since the RA is going to move much more.
Anyway, do what Kevin does... threat the RA and the declination guide parameters as independent adjustments. Don't use for example, 150ms max pulse width for declination just because 150 ms works best for the RA axis.
(If I were ZWO, I would have measured each motor/gear set, and reserve the better ones for the RA axis, while using the less good ones for the less critical declination axis :-).
