The installation of 2.1b on several iOS devices and two ASIAIR Plus went perfect.
bug report:
"center here" works wrong (RASA36, one mirror telescope. Comec 10micron HPS3000 mount)
"Scan ASIAIR in current network" does not show results when remote connected over VPN. But if you enter the IP manually, it still works (I dont know if its possible to scan remote)
The blue dot in the objects database should be at the actual time, this went here wrong several times.
suggestions:
switch between 2 ASIAIRS could be so much easier and faster when you already display the available ASIAIRs and let the User simply click on them. Then restart the App without request or unnecessary startscreens.
The annoying rotating Startscreens anyway should be disabled by user checkbox (maybe the user can have their own start screen?). Tablet users have to turn their tablets. Especially if the tablet are mount in a fix holder, this is not possible. Forget phones, almost nobody use them.
If refocus fails (because of clouds), PLEASE at least go back to the last value and continue shooting. As an extra you could track the focus vs temperature and the choosen filter and automatically insert the right value for the EAF with the time.
Please make the redesigned buttons bigger. Even on a big tablet they are to small.
Please make an extra button to enter the object database, I use it a lot. In the "best of" collection please make a "best of including fainter objects" available. Please include the the vDB and the Abell catalogue. For the filter criteria please add minimum and maximum size of an object displayed.
Please use for your planetarium a stronger background image (more and fainter nebula visible) and please make a button to turn off these disturbing constellation signs.
Please make user configurable text for the ASIAIR outputs possible (e.g. fan, light, switchbox, observatory shutter, rear heater, front heater, etc.)
Make dithering without guiding possible. I use a high quality mount, mostly without guiding.
In autorun and plan it would be nice, instead of leave the math to the user, if you simply enter the integration time and the single exposure time. E.g. from "18:00-20:00" or "2 hours".
For EAF users it would be great if you can bind a default position (maybe also a temperature gradient for users of your thermometer add on) to each filter. Example given: Filter "Halpha" with preset EAF to 45000. Not all filter are homofocal to each other.
Just some suggestions.
I use 2 ASIAIRs in my roll off observatory, completely remote. I am very happy with the ASIAIRs. It makes the use so much easier. Thank you for making this also running with Apple Silicone computers. The trend is to automate shooting even more in the future.
http://www.possi.space
http://www.possi.space/astrofotoselection
