Chen, I completely agree. This is iOS, not Windows (always as many clicks and modal dialog boxes as possible ...). Launch the app and go directly to the app workspace. That would be as elegant and simple as possible.
Hi, I have the ASI Air plus. Recently purchased from OC Telescopes. I'd like to try my Sony A5100 camera. Is it possible that the A5100 can be supported? It was a very widely sold camera.
By the way, I have an astro modified A7s, I will try that as well.
I recently downloaded ASIAIR v2.1.48/10.71, successfully installing it to my AAPlus. Using it with my ASI6200MC, ASI1200MM-S, and Ioptron CEM40 mount, I didn't observe any real problems during an imaging session apart from what I perceived to be a slower processing of image transfers for Preview mode display. From what I've seen in comments, that problem has apparently been recognized and addressed, so that is great news.
Given my AAPlus success, I decided to move on to installation to my AAPro, for use with my Nikon D850, ASI1200MC-S, and Star Adventurer Pro tracker which uses an ST-4 connection only. I immediately saw a problem upon launch of the app, in that there was no initial configuration page provided for Location entry and setup of the main camera, guide camera, and mount. This seems to be unique to a mount connection via ST-4, because upon reselecting my CEM40 goto mount and changing the wi-fi back over to the AAPlus, then exiting and re-entering the app, I was presented with the configuration page as expected. This page remains particularly important for manual entry of the location when using an ST-4 connection and especially in the absence of GPS data on the host device.
UPDATE:
I continued later in the day with the exploration of this problem and have found it seems more common with a tracker and ST-4 only connection, yet I have now confirmed its occurrence also with my Ioptron CEM40 goto mount. What I discovered, and this is unique to the new app release, is that the initial configuration page that I was expecting to see anytime I restarted the app (as historically has been true of pre-2.1 versions per my observation) is now being presented only if the ASIAR is rebooted. If one remains on that page without entering the app further and restarts the app, then again the initial configuration page is presented. However, if that page is left to proceed into the app, then it is no longer provided even with a restart of the app. To obtain it again, the ASIAIR (Pro or Plus in my case) must be rebooted. This seems a significant oversight, in that if no GPS source is available to automatically populate the location data then manual entry of the location is required, yet cannot be completed unless the ASIAR is rebooted.
Such errors impact being able readily/easily obtain a polar alignment. If the operator is working remotely from the ASIAIR and wants to inspect the location data, there is none provided for trackers, only goto mounts. So, the operator must have access to the initial configuration page to confirm the correct initial settings of the location. In the past, this has been available by simply exiting the app and re-entering it, but this no longer seems true. Apart from the problems this creates for the operator, I would suggest further that there is a value in having a button made available for selecting the initial configuration page so that location updates can be preformed. Alternatively, on the Mount page where Location information is accessible for goto mounts, make that same information available for tracking mounts.
Thank you!
Hi.. is possible use both versions? example: beta 2.1 on my phone for testing and 2.0 stable on my ipad
    Marco_B you may be aware that with each update of the app, there is typically a new firmware release associated with it. When the app is launched with a version other than that which it is paired, you will be presented a notice of a mismatch. I'm assuming your question is based upon working with a mismatch and not with always resetting to the firmware that is properly paired with the app you are using. If the mismatch notice provides an option to proceed without requiring you to update, then yes, you can run the app with differing firmware. However, in doing so, the credibility of any problem you encounter would be questionable, so this would be something done at your own risk with regard to your imaging session. Most likely, you would run the new app with the older firmware so as to retain the stability of the older app while attempting to explore the features of the new app but with firmware that has not been updated for it. Your results would be unpredictable in the latter case and if problems arise that you have questions about, you would absolutely need to report your usage being with mismatched software & firmware. Depending upon the nature of the problem, ZWO may recognize the issue isn't mismatch related and investigate it, but the more likely response from them - based upon my own experience as a software test engineer - would be to advise you to update the firmware to match the app before reporting a problem.
    Still sad that this company refuses to support other focusers. I would have one on all of my setups if EAF wasn't the only option. I'm sure there is a lot of people that would agree.
    This company needs someone else at the top that actually listens to customers.
    I have read so many of the posts on this forum requesting support for other focusers. Every one of those requests could have been another AsiAIR sell and for me, it could be 3 sells. Some even returned equipment and decided to never buy from ZWO again. Ill reiterate that is a terrible business model especially for a company already in a niche market.
    • w7ay replied to this.
      cashd115 Still sad that this company refuses to support other focusers.
      Considering how much resources they have to put into ASIAIR, the product might actually be a loss leader.
      https://www.investopedia.com/terms/l/lossleader.asp
      Unlike open sourced programs, ASIAIR's main reason for existance is not to make the user happy, but to capture novice users (who are the ones wanting "easy as 1,2,3," instead of "better than 1,2,3" programs) into their eco system. ASIAIR exists to sell more cameras (and thus also OAG), electronic focusers, EFW, Mounts, etc, etc.
      Supporting other manufacturers' focusers would just defeat the purpose of marketing the ASIAIR.
      Their recent release of an even cheaper ASIAIR is further example of that strategy.
        Hi all, I just cannot plate solve. Everything was working fine until the most recent update 2.1-10.71. And really I have had issues with plate solving continually since the updates hit v2, before then I have never had issues with anything. Everything all went smoothly.
        Celestron EdgeHD8 with 0.7 reducer
        Celestron 0.7 Reducer
        Celestron OAG
        iOptron CEM40G
        533MC Pro
        174MM Mini guide cam
        AIR Plus
        ZWO EAF
        I have made sure the focal length is correct that the scope is focused. I have set it manually and set to 0 for the air to calculate it, with no success.
        I have uninstalled and re-installed.
        I really do not know what more I can say, I am completely lost as to what to do.
        Regards
          ShinyAstro I have made sure the focal length is correct that the scope is focused. I have set it manually and set to 0 for the air to calculate it, with no success.
          Before asking ASIAIR to auto plate solve, try doing it manually from the Preview window where you can adjust gain and exposure times. Plus, you can also use the Detect Star tool in the Preview window to check if ASIAIR can actually see a good number of stars.
          First, make sure that you have tack sharp focus. This is crucial. Try focusing first with a Bahtinov mask.
          Next, adjust gain/exposure time so that the plate solver can detect between 50 and 200 stars. I have seen it solve with as few as two dozen stars. Try to adjust gain/exposure time so that not too many of the stars are saturated, otherwise you have fewer stars in the database to rely on -- as far as I can tell ASIAIR rejects over-saturated stars (stars whose diameter are over some amount) when plate solving. This is also why unfocused stars don't plate solve.
          Make sure there are no shadows, such as chimneys and tree branches, or a small patch of clouds in the camera's view. It confuses the heck out of the ASIAIR plate solver.
          Finally, don't even waste time plate solving above +60º or below -60º declination angles (i.e., within 30º of the poles). ASIAIR does not have sufficiently good database in those regions. Use the astrometry.net web plate solver for those regions.
          Plate solve only involves your OTA and the main camera. Nothing else matters -- the OAG does not come into play (unless the prism casts a shadow), the mount does not come into play, and the guide scope does not come into play unless you are plate solving the guide camera.
          Tree things please:
          1. "center here" does not work with my RASA36 (a one mirror-telescope, so mirrored image). This function was very helpful for widefield image composition.
          2. with the new Sony support please produce the discontinued the Sony E-mount adapter (or a better version).
          3. Please remove the rotating splash screens, they makes me really angry and nervous (I use a a holder in my observatory for my iPad in fixed landscape mode). This make your software from the beginning look like cheap crab - but in fact ist a high quality, expensive product. www.possi.space
          Hey I have a problem, I'm not sure if it is related to the Beta.
          First my Setup: ASOAIR Plus with Beta Software and a Sony a7iii with a 420mm APO attached to an SkyWatcher StarAdventure 2i.
          Yesterday was my first night in the field with the ASIAIR Plus, the setup PolarAlignment etc. was no big deal, then i searched my target M33 also no big deal.
          I took some Preview Pictures to test, and it looked perfect to me, then I set up an AutoRun and Started it, but with the first picture taken I was confused it was Low Resolution I mean 984x662 Pixels i stopped the Autorun and took another Preview and the Resolution was Ten times better and accurate to the FullFrame 6000 x 3376 pixels big Sensor.
          I thought maybe it's just a Preview and let it run further, after 2 Hours I run into the Horizon so i changed my Target To the Pleiades same thing Preview looks awesome, but now the Actual size is 1312x882 pixels.
          After some time I packed up and today I wanted to process them and I saw that the Size from above is the real size of the .fits.
          So now my first question is there a setting parameter that i don't know or is this a Bug. I searched a lot but cant find anything.
          And my second question is there an Option to save the Pictures also directly to the SD Card in the DSLR:
          Greeting Jake
            pxljake the filenames do reference binning (Bin3 for the Pleiades and Bin4 for M33) so the reduced resolution kinda makes sense. Have you set it manually to those values or did it on its own?
              @PMTeam@ZWO just noticed the shut down label on the power off slider is misaligned in 2.1.53 and previous versions. Also, is it just me or two buttons would have been better? I do understand that this way it would be harder to accidentally restart/power off the unit, but still I find them awkward to use.
              erossi Ohhh now everything makes sense and yeah im pretty sure I changed it.
              I know Binning and used it with my old camera but I was not even close to connect one to another, In my head bin 1-4 were folders or sorting options of some kind.
              Thanks al lot i can’t think around how stupid i was
              PMTeam@ZWO Can you guys take a look at my topic regarding the problem with All Sky Polar Alignment (ASPA)?
              After the update to 2.0/2.1, I was never able to polar align again through ASPA (AzGti and Asiair v1). The Tracking seems to be Off, even though it shows On in the menu, and the error just accumulates at a constant rate during the adjustment phase (after the 3 plate solving routine).
              I managed to downgrade to 1.9.1 using a 3rd party app manager (Aptoide) (was a huge pain since ZWO seems to have complicated the access to previous app versions during the resource download within the app). It completely solved the issue!
              I have a topic with many discussions and a video showing the problem. This has been almost 3l4 months now not being able to PA!
                23/03 [2.1-10.74] New Public Beta Version
                DATE-OBS of FITS header: change to exposure start time
                Fixed the problem of inaccurate calculation of plan estimated time
                Fixed the problem that Canon EOS Rebel T8i does not recognize
                Fixed the problem of white balance in video
                Fixed the display exception when the camera returns an odd number of image pixels
                Fixed the star selection exception in Guiding
                This version still doesn’t recognize my Canon T8i. Is there anything else I need to do?
