Hello,
There is a significant difference in guiding and tracking behaviour for my AM5 before and after the flip.
The test data from last week is given below. However, on going back through the logs, this has been the pattern since I got the AM5 in November. It became more noticeable after I started using an RC6 on it.
Some points.
- The error is still within the 0.5-0.8 range quoted by ZWO.
- This issue is only when imaging in the East at a pixel scale of 0.56, again less than the 1.0 or so recommended by ZWO for this mount.
- Still, the mount has run for couple of hundred hours now, and the issue is always when pointing East (i.e., scope is West of Pier). It would be great to understand what is happening and be able to take whatever action is needed.
- It works beautifully even at this focal length and pixel scale when pointing West. So obviously I would like to have the same performance when pointing East :-)
1. First, Summary of data (Order of settings / results is RA/Dec/Total)
Pointing East / West of Pier
Time: 1h17m, 1.5sec, Gain 65%, Hysteresis, Minmove 0.10/0.35, Aggression 80%/80%: 0.67/0.35/0.75
Time: 1h27m, 1.2sec, Gain 70%, Hysteresis, Minmove 0.10/0.35, Aggression 70%/80%: 0.64/0.29/0.70
Pointing West / East of Pier
Time: 1h21m, 1.2sec, Gain 70%, Hysteresis, Minmove 0.10/0.35, Aggression 70%/80%: 0.47/0.34/0.58
Time: 1h27m, 1.2sec, Gain 70%, Hysteresis, Minmove 0.10/0.35, Aggression 70%/80%: 0.50/0.37/0.62
A CN user OzAndrewJ was extremely helpful and analysed the logs, which can be seen at https://www.cloudyni...lub/?p=12505082
Basically, the RA when WoP is more rough and complex - no discernable pattern. After the flip its much more stable and like the ZWO chart.
Second, the behaviour chart for RA guiding RS for each sub, from the NINA metadata plugin
Third, the PEMPro FFT result
These are with guide moves added back, and set to "Favour Frequency" (though "Favour Amplitude" is similar)
When WoP, the dominant period is around 1100 sec but its 431 sec when EoP
The 1100sec period reaches a massive 38as when WoP but just 8as when EoP. However, the 431 sec amplitude is around 17as on both sides.
So something adds that huge 30as sec displacement with a period of 1100sec when the mount is pointed east.
Assuming it is a balance issue, I have so far tried
- Rough balance in Dec with a dovetail counterweight
- Reducing tripod height to stabilise the setup.
- PPEC instead of hysterisis as the guide algorithm
- Changing guide exposures between 1.0 and 1.5 sec, and aggression between 45-70%
No significant change.
Scope: RC6 + accessories, guiding with OAG, imaging at 1370mm FL, total weight around 8kg
Tripod: TC40, 5kg weight in weight bag.
Control: ASCOM/NINA/PHD2
Any suggestions / ideas are requested.
