Hello to everybody.
I use a 12V - 10A power supply to power AsiAir Plus. I use AsiAir 12V power outputs to feed the following devices:
- 12V output to feed HEQ-5Pro mount
- 12V output to feed Belt Defog Heater
- 12V output to feed Asi294 Pro camera
When I switch ON the Belt Defog Haeter, the red led on HEQ-5Pro start flashing. When switched OFF and mount is moving (during a GoTO), Led sometimes switch OFF then ON quicly 1 time, 2 time then remain correcty ON.
I got some HEQ-5Pro treat discussion on different forum and this behavours seems to be related to a under voltage issue.
Power supply Voltage is 12,15 but Voltage satatus on AsiAir App is always 11,7.
So I have 2 questions :
- What is the min and max power voltage supported by AsiAir Plus ?
- 12V power output port are internally regulated or not ? In other words, if asiAir is powered at 13,8V what is the
output voltage of output port when are active ? 13,8V or 12V.
Many thanks for any informations regarding this issue.
Ernesto
