w7ay Thank you for the detailed response on this.
I calculated the slope of the first wave's right slope, I don't remember what it is called, basically its the right-side slope/declination slope of the 1st waveform, and you chose the inclination which indeed is the worst slope it seems.
So I tried changing the settings just to give it a try as you mentioned today, I set both RA and Dec durations to 133ms and started calibration pulse with 1000, then 1500, and 1800, guide scope exposure to 2 seconds.
It seems the DSO target I am aiming at, is at horizon when I start imaging (10pm PT onwards) - SH2-132 (Lion's Nebula). I use a asi120mm mini for guiding, and I noticed as time passed and the target moved upwards (around 12am PT), the guiding improved quite a bit, with the default settings on ASIAir+ (1800/2000) calibration step, max dec and RA at 2000. I know it is not what you recommend or believe to be accurate, but that still gave me a consistent total error of 0.5-0.6.
One thing I noticed which is kind of a serious problem to me is I am imaging at 300s and I notice a huge spike periodically in the total error, not necessarily RA/DEC individually, the error jumps to 3-4 etc. and it is not the dithering, because I have enabled stability parameters as well in ASIAir+.
So I am wondering what is causing this, is it because I have a high harmonic error/higher worst slope etc.
Or is this just a case of bad visibility. I live in a Bortle 8-9 but I use narrowband filters for imaging. I do my polar alignment on an empty filter slot, then refocus on a filter and start guiding. I don't necessarily need to do this, but I didn't want the polar alignment to mess up due to my sky conditions.
I guess I just want to make sure that the unusual guiding graph spikes are just because of poor visibility and not the mount itself. Any thoughts on this?
EDIT:
I want to note that, in clear conditions (lower bortle zones) 133ms max RA and DEC, calibration step at 1000/1800, 1/0.5 exposures would yield excellent results, as I saw the guiding improving on these settings way quicker than they would at other settings, but they probably would cause problems if I have poor seeing conditions quicker as well.
