This is a ASI6200MC connected to a Sigma 135/1.8 ART lens using the Starizona adapter, with front aperture stops to stop the lens down to about f/2.93. The lens hood is removed to show the aperture stop. The ring gear for the focuser belt was custom 3D printed for me by deepskydad.com after I sent him some dimensions.
There is a trade off between using the internal iris (which is placed at nodal point) and using an external aperture stop. In the former case, unless you have 32 iris blades, will create difraction pattern in the form of radial spikes. On the otherhand, by placing an artificial aperture stop in front of the objective can lead to what is called aperture vignetting that causes a different kind of diffraction pattern -- you may have seen it before as a kind of halo around a very bright star with two notches in halo. I.e., at some point, the light cone causes the aperture to no longer look like a circular disk, but as something that looks like cat's eyes or a shape of an almond (whose Fourier transform is a halo with notches). You can read more about this type of vignetting here:
https://www.cloudynights.com/topic/547028-anyone-know-what-causes-this-artifact-on-bright-stars/
So, you get to choose between radial spikes (everywhere) or notches (near the edges of the frame).
This is why I avoid camera lenses except for short focal lengths, when I don't have much of a choice.
