I would like to use my ZWO ASI6200MC Pro camera with my Canon EOS EF L-Series lenses and 2" astronomic filters. I already have the ZWO Filter Drawer M54. The sensor in the ASI6200MC Pro is set back 17.5mm in the camera. And, according to the ZWO mechanical drawing, the M54 Filter Drawer will add 20mm to this distance when securely threaded into the camera. So, that's 37.5mm overall.
It is my understanding that the required backfocus for the EOS EF L-Series lens is 44mm, so the EOS adapter required should nominally be 6.5mm in depth (understanding that the filter thickness may require some additional shimming for proper spacing).
So, it would appear that based on the ZWO product description, The "Short EOS adapter for EFW & Cooled Camera (6.5mm backfocus version)" should be the correct fit for this application, right? And as for the threads on the short EOS adapter, are they compatible with the M54 threads on the "lens-side" of the M54 filter drawer?
I cannot find any specified dimensions for this short EOS adapter so I'd like to double confirm that my understanding is completely correct before purchasing it.
https://astronomy-imaging-camera.com/product/new-eos-lens-adapter-for-efw/
