Still several issues (both AM5 and AM3), the same as with the previous versions:
1) during moving North or South, the tracking is stalled.
This is very noticeable at 1x, 2x, 4x: the object moves diagonally, instead of only North or South.
This happens with both the ASIMount app and the ASCOM via a PC, so it is likely a wrong response of the mount.
I made sure the latest firmware was installed, and all drivers are up to date.
2) At speed 0.5x the tracking stops entirely when trying to move it against the tracking direction.
This is with te ASCOM driver. The ASIMount app doesn't allow 0.5x, but also at 1x it shows this odd behavior.
At higher speeds the response to East or West is as it should.
Could you please confirm that is the case for all AM5 and AM3 mounts, to make sure that is not due to the particular ones I happen to use?
In any case, could this be corrected? I would be very grateful. - Huib
